Vehicle: V5 2 Door STI
Engine: EG33 (Stage 3 4cyl spec)
Power: 768hp
Best E.T: 7.795 @ 176.93mph
Induction: Garrett GT55, Custom MOOD Motorsport Intercooler, Stock EG33 plenum, 12 x 1600cc injectors, Enderle 110 mechanical fuel pump, Billet fuel rails, stock throttle body's
Internals: Forged pistons, billet conrods, copper head gaskets, O-Ringed head & block, TRP 14mm Headstuds, Stage 3 heads, 4 stage dry sump system
Ignition: Microtech X6 with Bosch coil packs
Exhaust: 6" Straight through
Engine Management: Microtech LT-10
Boost Control: HKS 60mm Wastegate, Turbosmart eBoost 60psi
Drivetrain:
Clutch: Custom twin plate
Transmission: Lenco CS3 5 Speed
Diff: Ford 9", Moser 35 spline axles, Harrop alloy center and carrier, full spool, standard Subaru front diff with PPG LSD, front STI shafts
