Результаты опроса: Поставили бы вы себе такую штуку ?
Голосовавшие
14. Вы ещё не голосовали в этом опросе
  • Да
    4 28.57%
  • Нет, не удобно
    8 57.14%
  • Нет, дорого
    2 14.29%
Показано с 1 по 10 из 10
Тема: Секвентальный шифтер
    Вот такая ништячная штука существует.
    Устанавливается на штатное место и конвертирует переключения по шаблону H в последовательные. Сцепу все таки выжимать надо.
    Нашел вот тут : http://www.ikeya-f.co.jp/en/product_...n_shifter.html
    стоит в япии 168,000 Yen.
    Вместе с ним устанавливается электронное табло с указанием номера включеной передачи.
    Есть установочные комплекты на разные машины.
    Видео как работает:
    http://www.ikeya-f.co.jp/images/wmv/gdb-true.wmv
    http://www.ikeya-f.co.jp/images/wmv/sousa2.wmv
    Описание на англ.
    Many drivers might have the experience of shifting-error with normal H pattern during races or driving at circuit. We have developed the products for the purpose of wining the race.
    Shifting-error may cause time loss or a damage to transmission. In order to avoid this troubles, we have realized the sequential pattern shaft used for racing cars(F1,GT,WRC,D1,RACE,RALLY,etc...), which can be controlled only by mechanical control with our own inner mechanism. Some people might wonder why it has to be mechanical control, since the control systems equipped in the cars is normally controlled by oil hydraulics or electricity which brings enormous benefits to us and also remove the burden of operation form us.
    However, at the same time, those benefits steals a sort of warmth, human touch and comfort, and only targeted to produce the best conclusive result by building up every single mechanical operation without any time-lags.
    Of course, we have made various prototypes that used the oil hydraulics and electricity.
    However, we eventuated to have humanity in the operation and realized to avoid the control by oil hydraulics or electricity thoroughly to treasure the feeling of driving
    "SEQUEN SHIFTER"(Sequential Shifter) is the item which can convert H pattern to sequential pattern which can controlled only by shifting the shift lever back and forth.
    This can prevent the common shifting-error between 2nd and3rd , 4th and 5th and eliminate over-rev caused by shifting-error.
    The inner structure is designed to minimize the torque required for shifting and also heaviness for shifting lever upon synchronization by the optimization of dram groove so that the aggression against the synchronize is minimized.
    As stated above, we recommend that our "SEQUEN SHIFTER"(Sequential Shifter)is such a useful item which allows you to be totally concentrated on the breaking on entering corner, and can prevent the mission or engine troubles caused by shifting-error by providing the assured gear shifting, and it will cultivate the better taste f gear shifting.
    Это для тех кто в передачи не попадает, что ли :)
    На сти итак передачи включаются довольно хорошо. Ход кулисы небольшой. А вот перейти на 2 передачи ниже наверняка займет больше времени, чем с простой кулисой
    В Мосвке такая стОит около 1500 USD. Но это вчерашний день. Вот что нынче в моде (ценник в Москве около 3500 Евро, и сцепление топтать не надо :) )
    http://www.sssdrive.com/subaru.php
    Почти женский автомобиль
    Да, Рамиль, вот это ВЕЩЬ !!!
    С Уважением, Игорь
    Re: Секвентальный шифтер
    Видео как работает:
    Описание на англ.
    куйня этот ваш шифтер, ход рычага сильно большой
    Блядство какое то, я на типтронике так могу
    Забавная фигня!
    Стояла бы родная на моей машине - балдел бы :)
    Тратить на нее деньги, да еще такие - смурь!
    З.Ы. Знаю, что во втором ролике мужик по японии гоняет, однако не мог отделаться от ощущения, что он сейчас во встречку впорется
    Иерунда ! ! !
    мех - есть мех, автомат - есть автомат. неча изобретать велосипет. (его уже давно изобрели до тебя)
    У меня дома нет телевизора, поэтому я ем грибы и смотрю ковер
    Работала бы без сцепы - еще можно подумать, а так смысла нет. Реально- переход с 4 на 2 больше времени займет
    Описание на англ.
    Купи лучше кулачковую коробку
