Показано с 1 по 15 из 19
Тема: Встречайте:-) Subaru Legacy B4 2003 г.
    Приобрел вот такой аппарат Subaru Legacy 20GTB(2.0GT SPEC-B) (Это по номеру кузова выдала http://www.subaru-sale.ru/vin/)
    Подскажите знающие люди, что это за модель такая?
    Хотелось бы на такой же прокатится, что бы сравнить :)
    Re: Встречайте:-) Subaru Legacy B4 2003 г.
    На спек Б вроде 6МТ коробка и на спек-б алюминиевая подвеска+стойки бильштайн ? По двигу они вроде бы одинаковые с 2.0GT
    Если
    If he's willing to save more and get the spec B I think its worth it, although I'm partial.
    For one, the 6-speed is stronger than the 5-speed. Its exactly the same that's in the STi, aside from some different ratios. The Spec B, as long as its and 07+ has a better rear dif than the regular GT. It has the R180 Torsen diff that the STi has. Thats about the only things that are the same as the STi.
    Now the differences between the GT and the Spec B are as follows:
    Spec B has aluminum suspension bits, GT does not.
    Spec B has Bilstein Suspension, while better than the stock GT suspension,
    if he wants better handling, coilovers or struts & springs are the way to go
    with either, but out of the box, the Spec B will handle better.
    You can get Navigation and manual with the Spec B, Nav only comes with auto on GT.
    Spec B comes stock with sticky summer tires and 18" wheels, GT comes with sh**y RE92's on 17"
    However, they are both 7" wide, so an wider aftermarket rim and tire would be ideal.
    07+ Spec b's comes with Alcantara inserts, which HOLD you in the seat a little better, GT has only perforated leather.
    07+ Spec B's come with defeatable VDC, I'm pretty sure auto GT's are the only models available with that.
    Now some might thing some of these things are subjective, but it all comes down to what the person wants. If he's planning on doing heavy modifications both suspension wise and engine wise, I'd go with the cheaper one, but you'll most likely need to upgrade the tranny. However, if he's looking only to get mid 300's, while the 5MT should handle the POWER fine, the 6MT will HOLD up a little better.
    Коробка 5 ступка, стойки бильштайн.
    +1
    6мт пошли на рестайле, 260сил у тебя
    B4 BL5 GT Spec-B
    Forik SF5 T/Tb
    Forik SG5 STI
    Не... на палке 280 должно быть. 260 - это автомат.
    По птс 280 Вот еще:
    VIN CODE: BL5003810
    Выпуск: 12/06/2003
    Автомобиль: Legacy
    Код модели B13
    Код кузова BL5
    Цвет: 39D(BRILLIANT SILVER M)
    Код отделки: D20(OFF BLACK)
    Комплектация: QGH
    Модель: 20GTB(2.0GT SPEC-B)
    Двигатель: 20Y(2.0L EMPI DOHC Turbo 280PS)
    Привод: 4W
    Трансмиссия: 5MT(???? 5????)
    Кузов: S(?????)
    Подвеска N/S(???????)
    Давай лучше фоток :)
    как фоток закинуть? хотел свои выложить, не загружает почемуто...
    B4 BL5 GT Spec-B
    Forik SF5 T/Tb
    Forik SG5 STI
    В форуме "наш сайт" есть тема.. пошагово описано как
    Ок, сегодня выложу. Подскажите лучше, какие стойки поставить можно с пружинами, что бы мягко шла, а то на родных бильштайнах каждую кочку чувствую, уже поднадоело поярдком.
    Ну это сам понимаешь... или рулить хорошо или жопе мягко. Поставь каябу обычную гражданскую.
    каяба гуано! спросите у Хавока))))) он обратно на бильты перешел...
    ИМХА моя такова, что и бильты тож гражданские стойки)))))))) Афтар ты на куцках и тейнах еще не ездил, так что оставляй бильты- хоть какаято рулежка буит по сравнению с прочими гражданскими стойками и по комфортности они получше спортифных аналогов будут...
    Может у меня бильштейнам пришел ппц, ибо они родный стоят (так прежний владелец сказал), а машина с 2003 года, в ямках стука нет, но жестко просто ппц. (До этого был форд, с ним сравниваю)
    Может их отремантировать можно (прокачать)? Если да, то посоветуйте где это сделать?
    если все еще жоско, то им точно ни пипец)))))) если стучать начали или потекли, тогда либо ремонт, либо на выброс
    Легася с Фордом точна сравнивать не нада ))))
  1. Subaru Legacy B4 S Concept
    от Figaro в разделе Стайлинг автомобиля
    Последнее сообщение: 30.03.2015, 13:19
  2. Subaru Legacy 92'
    от YoshkinCat в разделе Приветствие и поздравления Subaru-участников
    Ответов: 15
    Последнее сообщение: 23.07.2010, 09:59
  3. Новая Subaru Legacy
    от Igores в разделе Offtopic
    Последнее сообщение: 13.01.2009, 10:35
  4. Subaru Impreza 2003 г.в., куз. GG2, двиг. EJ15, не заводится авто после аварии
    от yvoloshhuk в разделе Двигатель и навесное оборудование Subaru
    Последнее сообщение: 16.12.2008, 21:26
  5. Subaru Legacy/Legacy Outback|
    от Alexsei в разделе Offtopic
    Последнее сообщение: 13.12.2007, 20:50
