Для начала (возможно каких-то параметров не будет или будут слегка по другому называться):
A/F Correction #1 (%)
A/F Correction #3 (16-bit ECU) (%)
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
A/F Sensor #1 Heater Current (A)
A/F Sensor #1 Resistance (ohm)
Coolant Temperature (C)
Engine Speed (rpm)
Fuel Injector #1 Pulse Width (ms)
Ignition Total Timing (degrees)
Intake Air Temperature (C)
Intake VVT Advance Angle Left (degrees)
Intake VVT Advance Angle Right (degrees)
Knock Correction Advance (degrees)
Mass Airflow (g/s)
Mass Airflow Sensor Voltage (V)
Front O2 Sensor (V)
Rear O2 Sensor (V)
Throttle Opening Angle (%)
Vehicle Speed (km/h)
IAM* (multiplier)
Feedback Knock Correction* (degrees)
Fine Learning Knock Correction* (degrees)
Manifold Relative Pressure (Corrected) (bar)
Engine Load (Calculated) (g/rev)
Idle Speed Control Valve Duty Ratio (%)
Primary Wastegate Duty Cycle (%)
Throttle Sensor Voltage (V)
PS: список для турбо, года выпуска от 2003 и старше.
9Нравится
