Для проверки крышки/клапана надо самому придумывать. По инструкции у япов есть такое устройство... в живую у нас я не видел.Сообщение от Teuton
Breather tank на атмо точно не нужен.
Этот не на субы.
Trust / GReddy (c)Radiator Breather Tank
Designed originally for racing engines, today’s compact production engines can also benefit from the used of GReddy’s Radiator Bleed Tank. By mounting the tank high up in the engine compartment, you can be assured that of a fully filled system with room for air expansion, thus reducing chances of overheating due to air-lock. Block-off radiator cap included.
