GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Our aftermarket boost controller allows you to
raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels.
Using our solenoid you are able to spool your Turbo quicker and maintain a rock solid boost level. We have made our solenoid to withstand 120psi, way more than any Subaru will see.
Revolutionizing the
Subaru boost solenoid market, we have created model specific install brackets that allow you to directly fit our Boost Solenoid into your
Subaru for a factory fit. No more Zip-tying! We give you the factory fitment you have been waiting for.
Staying with the OEM fitment theme, our Boost Solenoid uses a
Subaru style wiring harness so you can simply unplug your OEM solenoid and plug ours in. No more cutting the oem wiring and crimping wires together!
Also new to the
Subaru boost solenoid market, we have used ultra low-profile hose fittings to keep the unit as small and clean as possible. The hose fittings are nickel plated brass so you don't have to worry about them snapping off like the plastic hose fittings!
